  3. Allegro screen white out
  • Replies 36
  • Subscribers 173
  • Views 33800
PhilH
PhilH over 9 years ago
Running Windows 10 with 16.6 and latest hotfix. Windows 10 did an update the other day and now my Allegro screen whites out if I hover over the visibility tab or if I click on any other application that is open. This is happening on multiple computers at multiple locations. Any one else experiencing this? Anyone know of a fix?
  • PhilH
    Johan, that seems to correct the situation by not maximizing the Allegro window, thanks!!!
  • drobny
    drobny over 9 years ago
    Are you sure? Look -> dl.dropboxusercontent.com/.../allegro.avi
  • riklee
    riklee over 9 years ago
    I noticed that you have the infinite cursor. Try the following:
    Unset the infinite cursor - In the Display/cursor category of the User Preferneces set the pcb_cursor variable = cross
    Does that correct the screen?
    Set the variable infinite_cursor_bug_nt
  • drobny
    It isn't a matter of setting, the problem occurs after the windows update
  • Roger G
    Roger G over 8 years ago
    Hi I have noticed that the same happens if you are running win7 and 16.6 with areo turned on and have NOT turn off Disable visual themes on the allegro.exe properties. Win 10 does not have areo so this may have something to do with the issue. Have you reported this to Cadence.
