  3. Definition of Cut-off Frequency & How to use it correct...
  • Subscribers 163
  • Views 3645
Definition of Cut-off Frequency & How to use it correctly
archive over 19 years ago
According to the FAQ " Calculating Impedance in SPECCTRAQuest " the following is stated for when cutoff frequency in simulation preference is set to non-zero values: " The field solver usually provides the frequency dependent RLGC parameters up to 50GHz to cover the asymptotic behavior of those parameters. "
I would like to know how is this 50GHz boundary is being defined and how is this related to the non-zero value that you key into the cutoff frequency menu.
Is this cutoff frequency has anything to do with the rise/fall time of a signal and is this value has any relationship with the one that Howard Johnson has defined in his MAGIC book ( the knee frequency )?
For example, if I have a signal that has an edge rate of 100ps ( 10/90% ) so what will be the cutoff frequency that I should key-in in order to make sure the loss calculated in the field solver will cover the bandwidth of this signal?
Thanks very much.
Michael Chan
Originally posted in cdnusers.org by kingseiko
    I'd take the cutoff frequency, in the simulation preference, as the max excitation freq contained in the signal edge.  This is approximated to :.35/tr.
    So in your case, this would be .35/100e-12= 3.5 Ghz.
    Originally posted in cdnusers.org by elie
