  3. loss of components when open schematic on another PC
  • Subscribers 166
  • Views 13616
HoLyNight
HoLyNight over 6 years ago
I used orcad 16.5 to design the schematic but when I copy the project to other computer ( orcad 16.5 too), I face to this problem. all the components in schematic are loss like the picture attach. I try it with other 2 PC, one is ok but one is have same problem. anyone face to this problem please help me.
  • Robert Finley
    Robert Finley over 6 years ago
    First, make sure your installation has the latest service pack when graphics problems happen.
    Your symbols *should* be cached in your schematic DSN.
    This isn't 17.2, so I'd look at your settings.
    Does this happen with all schematics or just this one on other machines?
    Worst case, try deleting your Capture.ini config file (after making a copy of it) to see if an option was accidentally set.
    To reset your color preferences on a machine that does this, at the Design Manager tab, click Options> Preferences> Use Defaults> (down at the bottom)
  • HoLyNight
    HoLyNight over 6 years ago in reply to Robert Finley
    thank your answer, in my schematic, it just happens with one sheet, I have 3 sheet in project and 2 other still working
    I will try your solution.
  • Robert Finley
    Robert Finley over 6 years ago in reply to HoLyNight
    Well, if it's just one page out of three, the problem isn't global settings that I was trying to address.
    Sorry about that.  But, it's weird that it isn't happening across all machines.
    But, you might get lucky and it goes away with a new Capture.ini file.
