  3. Perception EDAC problem and need hotfix verion 40 for 17...
  • Subscribers 172
  • Views 17937
Perception EDAC problem and need hotfix verion 40 for 17.2
TiBo
TiBo over 7 years ago
I have problem with EDAC connector when I use Cadence 17.2 (052) hotfix.
It works with bare basic installation of 17.2 (000) and one person in the company have hotfix 40 and it seems to work too.
Anybody is use EDAC connector? Please give me some ideas.
And how can I down load an older version of hotfix?
TiBo
  • oldmouldy
    oldmouldy over 7 years ago
    You will need to provide some more details, like which EDAC connector, since EDAC manufactures many connectors. And what specifically is "the problem"? You can't place it, you can't route to it, or whatever? And what do you mean by "works"? You can place the Package Symbol / you can route to it, or whatever. Check the Command window in PCB Editor for any messages. If you don't have a local archive of hotfixes, it's unlikely that you will be able to get a specific hotfix via this forum.
  • TiBo
    TiBo over 7 years ago in reply to oldmouldy
    This is perception software, it is EDA connector, this tool is attached to Orcad capture. It allows us to work with Agile to create part numbers, upload files to Agile and create the BOM.
    TiBo
  • Adrian Hobbs
    Adrian Hobbs over 7 years ago
    I believe that the old Perception Software tools are now owned by Altium, you might try contacting them to see I you can get some support for the EDA Connector. Good luck.
  • steenkg1
    steenkg1 over 7 years ago
    We have the same issue. We have raised a ticket at Perception. They are working on a sollution (i hope)
  • educationrecto
    educationrecto over 6 years ago
    [deleted]
    • Vote Up -1 Vote Down
