  3. ground plane/pour
  • Subscribers 166
  • Views 4004
ground plane/pour
bobs57
bobs57 over 6 years ago
i'm trying to add a ground plane to a board. i am following a tutorial. everything works good following instructions but in the tutorial the ground plane has a transparant color.  my rectangle has none and i've been unable to find a way to do it.
any help appreciated.
  • Adrian Hobbs
    Adrian Hobbs over 6 years ago
    You may need to turn on OpenGL support to see the translucent shapes. Try using the menu option 'Setup>User Preferences' , then 'Display - Opengl' option . Make sure that 'Disable_Opengl' is NOT selected. There's also a control for 'transparency levels' in the color dialog menu on the Display tab, try adjusting the percentage of Opaque to see if that helps ?
  • Adrian Hobbs
  • CadAce2K
    CadAce2K over 6 years ago in reply to Adrian Hobbs
    Been ages Adrian! You haven't retired yet? Are you racing Mike Goode to the finish?  :)  Sayin' "Hi" from San Diego.
