  3. Problem generating PDF files with Nordcad PDF Generation...
  • Subscribers 162
  • Views 19029
Problem generating PDF files with Nordcad PDF Generation utility
Lennie
Lennie over 7 years ago
Hi <
Anyone else having a problem generating PDF files with Nordcad PDF Generation utility ? it works ok on windows 8.1 but not on windows 10. I get the following problem.
Running PDF generation utility 4.05 - (C)Nordcad Systems A/S - info@nordcad.dk
*Error* fprintf/sprintf: format spec. incompatible with data - "Format is '%s/ns_tmp', argument #1 is nil"
  • steve
    steve over 6 years ago
    Try updating to the latest version of NsWare PDF.
  • Lennie
    Lennie over 6 years ago in reply to steve
    Thanks but that is the latest version.
  • steve
    steve over 6 years ago in reply to Lennie
    I have version 4.68 so you are not running the latest version. Try a Google search for nsware pdf and you should be able to find the NordCAD website which should get you the latest version.
  • Lennie
    Sorry. You are correct. I found that one and it works . Thanks!!!
  • RFinley
    RFinley over 6 years ago in reply to steve
    Could someone encourage Nordcad to update the Orcad marketplace?
    https://www.orcad.com/products/marketplace-apps/5761
    (4.05 there...)
