  3. Component Device Pin Number Mismatch; Cannot Replace
  • Views 17255
EASiA
EASiA over 6 years ago
Hi All,
I have been trying to translate a board made in Altium to OrCAD. When making the Netlist, I received the warning:
#3 WARNING(SPMHNI-184): Device library warning detected.
WARNING: U11 component device pin number mismatch; cannot replace.
The part is a simple 4 pin regulator. Both the schematic symbol and the PCB symbol have 4 pins, as far as I can tell. How can I resolve this?
  • CadAce2K
    CadAce2K over 6 years ago
    Obviously the Altium part is 'pin labelled' different than the Orcad footprint. The Altium netlist should be editable (e.g. text file), so look up U11 in the file and see what they label the pins as (maybe like 1A. 1B, 2A, 2B?). Then map the U11 footprint accordingly.
  • CadAce2K
  • EASiA
    EASiA over 6 years ago in reply to CadAce2K
    Hi CadAce2K, I did not fully understand what you meant. I was finally able to understand that even though I made the schematic symbol have 4 pins, I did not label the number correctly for it to match the current footprint that was made. I mistook pin number mismatch to be amount and not a label of sorts. I understand now that device pin number mismatch means that the number label of the symbols and footprints have to match and not meaning the amount of pins.
