  3. Allegro reference designator's text size
  • Views 16077
archive over 19 years ago
Hi all,
I am using Allegro 15.2 and I want to change component reference designator's text size manually but I don't know how to do it. If I try Edit -> Text, all I can do is just changing the text string but I cannot change the size of the text. Can anybody help me with this problem?
Thanks.
Originally posted in cdnusers.org by damian_s
    Hi damian_s.
    Do You want change Reference text size?
    Using>>
    1. Menu>>> setup - textsize click
    2. text setup window
    1> finde designed the text block number
    text block check by show element
    2> using text block change width,height
    line space,photo width,char space.
    change value of do you want?
    3. color and visibility window
    1> all invisible
    2> components group change
    Ref Des section all visible.
    4. Menu>> Edit- change click
    1>control panel
    text check of find tab
    text block change of opinons tab
    so you want text size of this brd.
    regard.
    Originally posted in cdnusers.org by sean
    Hi damian_s.
    Using>>
    1> all invisible
    1>control panel
    regard.
