  3. When the net schedule is set in the PCB editor and auto...
  • Views 14197
When the net schedule is set in the PCB editor and auto-routing is executed, the routing is different from the set schedule.
wjavos
wjavos over 5 years ago
Hi i am Vos.
Is there a solution to this problem?
thanks.
  • steve
    steve over 5 years ago
    This could be related to the license level you have. What license are you running?
  • wjavos
    wjavos over 5 years ago in reply to steve
    I run the Allegro pcb Designer with high-speed option.
  • steve
    steve over 5 years ago in reply to wjavos
    So I tried this on a simple net and it obeyed the schedule. I checked my license log file and it used SPECCTRA_PCB, SPECCTRA_autoroute, SPECCTRA_HP, SPECCTRA_256U. Check your license file so see if you have any of these (but the HP one specifically).
