  3. Assembly drawing , allegro
  • Views 13409
madboss
madboss over 5 years ago
Hello all ,
     I'm using orcad  17.2 . Try to export -variants- create assembly drawing  in orcad  . But it shows variants.lst file not found . How to overcome this . Anyone kindly explain details...
Thanks & regards ..
  • steve
    steve over 5 years ago
    You need to make a variant.lst file using OrCAD Capture CIS (where your variants are defined). In Capture CIS open Part Manager (where you define variants) and then run Reports - Variant Report which writes the variant.lst
  • steve
