  3. NO_TEST Property
  • Subscribers 163
  • Views 13329
NO_TEST Property
archive over 18 years ago
I have a large design where approximately 1200 nets do not require manufacturing ICT access.
The board manufacturer has suppplied a list to me which details which nets do not require access.
Using this list, is there a way of adding the NO_TEST property automatically to these nets?
Originally posted in cdnusers.org by cmhillman
    If the list of nets is in the following format you can use the Find by Name section of the find filter to accomplish this task easily. The list of nets should be in the form of:
    C
    UN1LS007PY0
    Q1
    A
    B
    RESET
    VDD
    GND
    Have the list of nets in the above format and name the file "no_test.lst"
    In Allegro select Edit > Properties
    o Set the Find by Name to "Net" and "List"
    o Browse for the file
    o In the "Open" dialog select the file e.g. no_test.lst; Select "Open"
    In the Edit Property Dialog that is presented select the property, in this case "No_Test", and move it to the right.
    Select "Apply" to add the property to all of the nets
    OK the Edit Property dialog
    Done the command
    Originally posted in cdnusers.org by Trykon
    Thank you
