  3. Create a simple form with SKILL code
  • Subscribers 161
  • Views 16856
Alice
Alice over 16 years ago
I am trying to understand how the form works in SKILL. Hence, I read thru the agroskill.pdf and tried to run the 2 sample skill, myExtractViews.il and formpop.il. However, I got those errors:-
Skill > load "myExtractViews.il "
function myExtractViews redefined
function _extract redefined
function _formAction redefined
function myExtract redefined
t
Skill > myExtract()
E- *Error* axlFormTitle: argument #1 should be any user-defined (other) type (type template = "ot") - nil
ERROR
Skill >
Skill > load "formpop.il"
function _popAction redefined
function myPop redefined
t
Skill > myPop()
"Error! Could not create form."
ERROR
Can anyone help? how to solve the error? also, any sample of the skill using form for me to learn ?
Thanks a lot =)
Alice
I cannot fine the attach icon, so I am copying the skill code as below:-
; myExtractViews.il
; -- Displays a form with a selection list of
; the available extract definition files
; -- Lets the user select any of the files on
; the list as the “View file”
; -- Starts Allegro extract process with the
; user-selected View file when
; the user picks Done from the form.
; Function to extract user selected view to the output file.
(defun myExtractViews (viewFile outFile)
axlExtractToFile( viewFile outFile)
); defun myExtractViews
; Function to start the view extraction
(defun _extract ()
myExtractViews(
buildString(list(cadr(parseString(
axlGetVariable("TEXTPATH"))) selectedFile) "/")
"myextract.dat")
); defun _extract
; Form callback function to respond
(defun _formAction (form)
(case form->curField
("done"
(axlFormClose form)
(axlCancelEnterFun)
(_extract)
t)
("cancel"
(axlFormClose form)
(axlCancelEnterFun)
nil)
("view_file"
(if form->curValue
(progn
; Accept user input only if on list
if(member( form->curValue fileList)
then axlFormSetField( form
"view_file" form->curValue)
else axlFormRestoreField(
form "view_file"))))
t)
("file_list"
(axlFormSetField form "view_file"
form->curValue)
selectedFile = form->curValue
t)); case
); defun _formAction
; User-callable function to set up and
; display the Extract Selector form
(defun myExtract ()
fileList = (cdr (cdr (getDirFiles
cadr( parseString( axlGetVariable("TEXTPATH"))))))
form = axlFormCreate( (gensym)
"extract_selector.form" '("E" "OUTER")
'_formAction t)
axlFormTitle( form "Extract Selector")
axlFormSetField( form "view_file" (car fileList))
selectedFile = (car fileList)
foreach( fileName fileList
axlFormSetField( form "file_list" fileName))
axlFormDisplay( form)
); defun myExtract
; formpop.il - Create and display a form with a popup
; Form call back function to respond to user selection of any field in the form
(defun _popAction (form)
        ("done"
          (axlFormClose form)
          (axlCancelEnterFun)
          t)
        ("change_pop"
          (case already_changed
              (0;Use display/dispatch string pairs
                  axlFormBuildPopup(form "my_popup"
                  list(
                  list("NewPopup A" "mynewpopup_a")
                  list("NewPopup B" "mynewpopup_b")))
                axlFormSetField(form "my_popup"
                    "My First Popups")
              (1;Display string/dispatch integer pairs
                    list( list("NewPopup 12" 12)
                    list("NewPopup 5" 5)))
                        "My Second Popups")
                  (t;String is both display and dispatch
                      list( "MyPopNValue1"
                              "MyPopNValue2"))
                               "My Third Popups")
                      already_changed++
                      t)
          ("my_popup"
              printf( "Got my_popup event:
                  form->curValue %s", form->curValue)
              if( form->curValue
                (progn
                 axlFormSetField( form "my_popup"
                      form->curValue)))
           t)
      ); case
; defun _popAction
(defun myPop ()
  form = axlFormCreate( (gensym) "popup.form"
          '("E" "OUTER") '_popAction t)
         if( axlIsFormType(form)
            then (print "Created form successfully.")
              else (print "Error! Could not create form."))
        axlFormTitle( form "Try My Popup")
        mypopvalue = "my_start_popup"
        axlFormSetField( form "my_popup" mypopvalue)
        already_changed = 0
); defun myPop
  • aCraig
    aCraig over 16 years ago
     Alice,
     It looks like you should execute  "myExtract()" not "myExtractViews()" . Make sure you have the .form file in your FORMPATH or the current working directory.
    There are other form examples at $CDSROOT/share/pcb/examples/skill/form. One of my favorites is "axlform" in the basic directory. It has an example of all the basic form features.
