  3. human ordering sorting challenge for skill
  • Views 17256
Ejlersen
Ejlersen over 12 years ago
Hi
I've numerous times come across the issue of sorting strings in a more "human way of thinking fashion"
I've played around with the different sorting predicates like 'lessp, 'alphaNumCmp, 'axlStrcmpAlpNum but none are really sorting in the way I would need. I had hoped the 'axlStrcmpAlpNum would do what I wanted, but mixed strings are a challenge.
Example (end sorting result that I would like)
"22"
"111234"
"111237"
"111a32"
"112323"
"11235a"
"11235f"
"abc211"
"xyz211"
I've come across some LISP code for this, but must admit that although I've done a lot of skill programming the code at the link below are a bit "black magic like" for me, it does not translate directly into a skill program
rottcodd.wordpress.com/.../
So maybe someone could shed som light on how to transform this into something usefull in Skill.
Hint:  www.davekoelle.com/alphanum.html has a number of other language implementations for the same type of sorting, it actually explain and illustrate the problem very nicely.
Thank you very much in advance
Best regards
Ole
  • Ejlersen
    Hi Olivier
    Thank you for your input on this, I got some code from a long time friend that I've been able to convert into something that can be used.
    I'll try your method to figure out if that works better for me. I'll however need to check for length since any length text must be after numbers, so "aa" will be after any string starting with a number.
    I'm in the same boat as you with numbers to strings, only aware of sprintf.
    Best regards
    Ole
  • Ejlersen
    Hi Olivier
    Best regards
    Ole
