  3. How to find out which env file is being used?
  • Views 29703
thewill2live
thewill2live over 11 years ago
Hey guys,
I edited my scriptpath in the global ENV file (located in the CDSROOT/share/pcb/text/ directory) as well as the local ENV file (located in the  CDSROOT/pcbenv/ directory) both to have a new entry for the scriptpath. Yet after loading up Allegro and clicking on Tools>Utilities>Env Variables it still shows that my scriptpath is set to some other directory (that is not listed in either of the two aformentioned ENV files).
 So my question is, is there some way to find out which ENV file is getting loaded by Allegro (besides manually looking up any and all ENV files in the directory)? This specific computer I'm talking about does have older versions of Allegro also installed on it, is it possible that it defaults to the oldest version's global ENV?
Thanks for any help you can give me.
  • oldmouldy
    oldmouldy over 11 years ago
    It's preferable to use Setup>User Preferences to set the User Preferences controlled by the Preference Editor, rather than edit the User Preferences section of the "env" file. The "env" file in the installation is especially NOT for user editing, the contents of this "env" file may be overwritten by Cadence product updates. Look at Tools>Utilities>Env Variables to see the "envpath" variable value, this lists the user(s) "env" paths and then the "installation" one.
  • thewill2live
    Thanks for the tip. I know that users shouldn't edit the env file directly, and when I edit things manually I do it from the user preferences like you suggested. The reason that I'm editing the file directly is that I am doing this from a python script (as a part of an installation suite for SKILL programs). I'll take a look at the envpath and see if that takes me anywhere. Thanks again for the help.
  • fxffxf
    fxffxf over 11 years ago
    If you manually edit your local env file place your edits as shown below (LOCAL ENV FILE),
     It is also not a good idea to override the Cadence supplied values in SCRIPTPATH. It is best to insert your entries in the front by:   set scriptpath = <your stuff> $scriptpath
    The env file attempts to read a site specific env file located at <cdsroot>/share/local/pcb/site.env.
    By default the env files are read in the follow order with 1 and 2 controll via the "source $TELENV" in the user's local env file
    1.     <cadence supplied> --- cdsroot/share/pcb/text/env
    2.      <company or site supplied>  -- cdsroot/share/local/pcb/site.env
    3.      <user supplied>        --- <home>/pcbenv/env
    -- LOCAL ENV FILE ---
     source $TELENV
    <<<<<  Put all your manual edits here >>>>
    ### User Preferences section
