  3. Exit axlSingleSelectPoint(nil) from blocking other code
  • Views 4062
leto
leto over 6 years ago
Hi All,
I'm using the function  "axlSingleSelectPoint(nil)"  to allow user to do a selection.
However, sometimes user may decide to exit this and run another function instead.
I want to allow user to click another button on my form to exit this function & run another function.
case(FormHandle->curField
  ("Button_Another_Function"
    axlCancelEnterFun()
    axlShell("done")
    ;; run some other process
  ("Button_Current_Function"
     ;; run current process
However  axlSingleSelectPoint(nil)  block all other code from running as long as user doesn't click a point
The form buttons work fine and I can enter the 'case' for 'Button_Another_Function' but all code does not run until use clicks a point.
Using "axlCancelEnterFun()" at the start of the new case doesn't work as this line will not run
May I know how to exit   axlCancelEnterFun()  without using options like RMB  cancel, done etc?
Leto
  • luanvn81
    luanvn81 over 6 years ago
    Hi !
     I have an idea that you can try to  built  a pop up  (ex: my_cancel)  for canceling while  processing  axlSingleSelectPoint()   and put that pop up  in your  "Button_Current_Function"  code.
    Tks.
    Luan
  • leto
    leto over 6 years ago in reply to luanvn81
    Thank you. I will try that.
