  3. paste mask openings only for populated components
  • Replies 7
  • Views 20904
DrHell
DrHell over 6 years ago
Is there a way to plot or copy paste mask openings only for populated components (i.e. components that do not carry the attribute 'do not populate') automatically?
Can you reference any pre-existing SKILL code that can be modified for this purpose?
  • B Bruekers
    B Bruekers over 6 years ago
    I believe the only SKILL way is to delete the paste mask from the padstacks.
    So basically:
    Find all affected padstacks (from components which are not populated)
    Create for each padstack a new one with axlDBCreatePadStack(), but without the pastemask
    Replace the padstacks with axlReplacePadstack() for all not populated components.
    Bram
  • B Bruekers
    So basically:
    Bram
  • DrHell
    DrHell over 6 years ago in reply to B Bruekers
    I see. Unfortunately, my skills in SKILL coding are not very advanced. Can you please refer to a SKILL code written for a similar purpose?
    Can I just copy the existing padstacks and delete the pastemask from it via SKILL, instead of creating new ones for every pad type which might be quite elaborative?
  • B Bruekers
    B Bruekers over 6 years ago in reply to DrHell
    I assume/hope that you have only a few padstacks in your 4000+ components PCB design?
    The idea is that you create a set of alternative padstacks of which the paste mask is removed. Then you simply replace the individual padstacks per refdes in the design.
    So something like this. Please take this as-is and change it for your own needs.
    ;axlDBCloak('_RemovePasteMask(list("C100" "U100")) '(shape ignoreFixed))
    defun( _RemovePasteMask (l_refdes)
        let( ((success 0) (fail 0) (skipped 0) pcre1 comp_dbID ps_newName ps_dbID bbox figureSize1 new_layer pad_list x y)
        pcre1 = pcreCompile(".*-NO_PASTE" 1)
        ;need to create 2 new mask layers where we will move the original padstack pastemask to.
        axlPadUserMaskLayers('create "NOPASTE_TOP")
        axlPadUserMaskLayers('create "NOPASTE_BOTTOM")
        foreach(refdes l_refdes
            if(comp_dbID = axlDBFindByName('refdes refdes)    ;get component instance. (not symbol or comp/symbdef)
            then
                foreach(pin comp_dbID->pins
                    ;only process SMD pins
                    unless(pin->isthrough
                        ps_newName = pin->definition->name
                        ;Check if padstack name is already changed. If not then create and change padstack
                        if(pcreMatchp(pcre1 ps_newName)
                        then
                            skipped++
                        else
                            sprintf(ps_newName "%s-NO_PASTE" ps_newName)
                            ;check if padstack can be loaded, otherwise create one
                            unless(ps_dbID= axlLoadPadstack(ps_newName)
                                pad_list = nil
                                foreach(pad pin->definition->pads
                                    figureSize = list( caadr(pad->bBox)-caar(pad->bBox)  cadadr(pad->bBox)-cadar(pad->bBox))
                                    new_layer = case(pad->layer
                                        ("PIN/PASTEMASK_TOP"        "NOPASTE_TOP"         )
                                        ("PIN/PASTEMASK_BOTTOM"    "NOPASTE_BOTTOM" )
                                        (t                                            cadr(parseString(pad->layer "/")))
                                    unless(pad->figureName=="NULL"
                                        push(make_axlPadStackPad(
                                            ?layer             new_layer
                                            ?type                 concat(pad->type)
                                            ?flash             pad->flash
                                            ?figure            if(pad->figureName == "SHAPE", pad->name ,pad->figureName)
                                            ?figureSize    figureSize
                                            ?offset             pad->offset
                                        ) pad_list)
                                ps_dbID= axlDBCreatePadStack(ps_newName nil reverse(pad_list) nil)
                                axlDBRefreshId(nil)
                            if(ps_dbID
                            then
                                if(car(axlReplacePadstack(pin ps_dbID))
                                then success++
                                else fail++
                            else
                                axlMsgPut('("Component %s: Could not change %s into %s." 3) refdes pin->definition->name ps_newName)
                axlDBRefreshId(comp_dbID)
            else
                axlMsgPut( '("Refdes %s not found" 3) refdes)
        when(plusp(success) axlMsgPut( "%d padstacks replaced successful" success))
        when(plusp(fail)         axlMsgPut( "Failed to replace %d padstacks" fail))
        when(plusp(skipped) axlMsgPut( "%d padstacks already replaced" skipped))
    ));defun
  • DrHell
    Excellent! Yes, I only have about 40 padstacks for which I have several unpopulated components. As far as I understand, I don't have to create new padstacks without the pastemask manually as this is done automatically by your code, correct?
    Also, as far as I can see, the code does not check whether the refdes linked to the pad carries the attribute 'note' with the value 'do not populate', right? It seems the code runs over all existing refdes which would include the components that won't be populated. Or am I missing something? Alternatively, I could easily create a list with the refdes that will be populated, but then this list need to be loaded at some point in the code?
  • B Bruekers
    The code will do everything, so create new padstacks and change them.
    Use this SKILL command:  axlDBCloak('_RemovePasteMask(list("C100" "U100")) '(shape ignoreFixed))
    Change the list("C100" "U100")  with the correct refdesses of which you want to remove the pastemask.
    ps. there is no undo-function, so backup the design before running this code or change them back by hand/force update of footprints.
