  3. Truncate a List
  • Subscribers 159
  • Views 13742
Truncate a List
leto
leto over 4 years ago
Hello All,
I have a list with a certain length.
I need to truncate it to make is a shorter list.
Is there a function that can do this most efficiently?
If not, any suggestion on the most efficient way to do this?
Thanks All.
  • DavidJHutchins
    DavidJHutchins over 4 years ago
    One possible solution would be to use the undocumented 'unique' function...
    testdata = list( "a" "z" "q" "w" "s" "x" "a")
    ("a" "z" "q" "w" "s"
    "x" "a"
    unique(testdata)
    Loading skillExt.cxt
    "x"
  • leto
    leto over 4 years ago in reply to DavidJHutchins
    Thank you David.  What i meant was if I had a list that was 5 elements and I want to create a copy of the same list but only up to 3 elements. Could it be done with a function?
  • DavidJHutchins
    try calling cdr() twice to remove the first 2 entries
    D:\Temp>il_allegro
    > testdata = list( "a" "z" "q" "w" "s")
    ("a" "z" "q" "w" "s")
    > length(testdata)
    5
    > newdata=cdr(cdr(testdata))
    ("q" "w" "s")
    > length(newdata)
    3
    > exit
    D:\Temp>
  • eDave
    eDave over 4 years ago
    nthcdr does this.
    eg. nthcdr(2 '(1 2 3 4)) -> (3 4)
    reverse(nthcdr(2 reverse('(1 2 3 4 5)))) -> (1 2 3)
