  3. Running bat files using axlRunBatchDBProgram
  • Views 18061
archive over 19 years ago
A while back, Frank gave us a hint that bat files could be run within axlRunBatchDBProgram. This works well (thanks Frank) and is a graceful alternative to system commands. However, I have problems with directing output to files within my batch files. ie. I might want to include this line in my batch file: dir *.* > c:\temp\files.txt The files.txt file is not created. Does anyone have a good workaround or know why this doesn't work? Cheers, Dave
Originally posted in cdnusers.org by Dave Elder
    Hi Dave,
    Not sure how you start your command, but you might want to try this.
    start cmd /seperate mybat.bat
    This will open a new DOS command prompt, which is idenpendent of the axlRunDBBatchProcess. Like opening a link in a new Window in IE.
    Just the bat file may not work. I think SKILL is launching your command as a new child process and I remember that DOS doesn't like this with bat files because it has to invoke the command prompt first.
    So the following might work too
    cmd.exe mybat.bat
    I am not sure what benefit you gain compared to using the system command in SKILL?
    If that doesn't work, you could write yourself a small wrapper in java. I think I have one somewhere.
    Andy ;-)
    Originally posted in cdnusers.org by andyk
    Thanks Andy, I'll check out your ideas. Mye batch file runs OK but the redirect doesn't create a file.
    Why I don't like system calls: The system command opens a DOS window, albeit briefly, on the workstation. With multiple calls, this can be quite distracting to the user. Cheers, Dave
  • Grungy Remnant
    Grungy Remnant over 17 years ago
    HI.  Did anyone ever have a solution for this?  I too am trying to avoid the system command to avoid the pop-ups. Although I don't need to run a bat file.   An example is the following CVS command:
    command prompt:   cvs watched >cvslog     this works and redirects the output to the cvslog file
    skill:     system("cvs watched >cvslog")     this also works as expected, including the
    redirect, but you get the cmd popup briefly
    axlSkill:  axlRunBatchDBProgram("cvs" "cvs watched >cvslog")  The cvs command works but the redirect does not work.  The same thing will happen using a bat file.  Adding cmd.exe in the bat file doesn't help either.  (ie. cmd.exe cvs watched >cvslog )
    So are redirects just not possible with axlRunBatchDBProgram or am I missing something?
    Thanks for any info!!
     CJB
  • wolfwang
    wolfwang over 17 years ago
    a good study skill website URL:   www.2ndevelop.com
  • Silver John
    Silver John over 14 years ago
     Hi, Dave, Grungy Remnant.
    I have similar problem (shell( "hg branch > ../hg.tmp").
    Are you found solution?
    Also question: what difference between system() and shell(), without regard for returning value?
