  2. RF Design
  3. take a fixed step time
  • Subscribers 63
  • Views 18142
kamel
kamel over 16 years ago
hi everybody
 did anyone know how to make a fixed step time for a transient analysis.
thanks
    Use the strobeperiod option on the tran analysis. Note that internally the simulator will still take whatever timesteps needed in order to accurately follow the circuit behaviour, and will also solve at the specified strobeperiod. It only outputs the timesteps at the strobeperiod.
    This makes it a very effective way of generating good data for performing an FFT on afterwards; it's regularly spaced, without interpolation errors which you'd normally get by sampling the data.
  • kamel
    thanks Sir;
    actually i need this for the FFT transform.
    best regards
    kamel;
  • garypyu2009
    garypyu2009 over 16 years ago
     Thanks for this information,..also need this one..nice to found answers here..thanks again..
  • HariV
    HariV over 6 years ago in reply to Andrew Beckett
                     Where can I find the "strobeperiod"  option in the ADE environment?
    Andrew Beckett over 6 years ago in reply to HariV
    Hmm. Please read the Forum Guidelines which clearly ask you not to post on the end of old threads (this one is 10 years old!), and also not to post duplicate questions. You've done both...
    However, since this is clarifying the answer above, I'll give a link to my response in the new thread you posted.
