  2. RF Design
  3. Need a transformer with adjustable primary/secondary/mutual...
  • Subscribers 64
  • Views 4768
Need a transformer with adjustable primary/secondary/mutual inductance and coupling factor
StillLearning
StillLearning over 14 years ago
Hello everyone,Could someone provide me with instructions on how to create a transformer with adjustable primary/secondary/mutual inductance and coupling factor in Cadence?Currently, there is "xfmr" in Analoglib; however, I can only specify the number of turns for the primary and secondary. There is also another parameter in the properties of xfmr that I am not familiar; it is titled: "Multiplier." Does anyone know what this "Multiplier" is?Thank you very much in advance for your attention and comment.Best,
Still Learning
  • Pournamy
    Pournamy over 9 years ago
    same question from side also. Can anyone suggest a solution for this.
    The xfmr corresponds to spectre's ideal transformer (see "spectre -h transformer" for more details). You can simply specify the number of windings on each side. The multiplier is a common parameter to all components in spectre, and means that you can place that number in parallel (probably little point in this case).
    If you want a non-ideal transformer, you could either use the approach described in "spectre -h transformer" or build one out of the winding and core components (see "spectre -h winding" and "spectre -h core" - these are available in analogLib too), or use a VerilogA model of a transformer.
    In addition, there is this paper you might find useful. The same site has downloadable copies of the models associated with the paper.
