  2. RF Design
  3. injection locked oscillator phase noise simulation using...
  • Replies 11
  • Subscribers 65
  • Views 14412
injection locked oscillator phase noise simulation using pss+pnoise
calp
calp over 15 years ago
Hi all,
I am designing an injection locked vco.  My simulation scenario for the phase noise is as follows:
1. Run the vco without the injection signal for 2 microseconds ; let it setttle to the free running frequency;
2. Start the injection signal and observe the phase noise...
 Well, I need a periodic vsine source to generate the injection signal in the schematic; and this is the very source of an error in my pss simulation:
" 'V0' is a periodic input signal, which is inconsistent with autonomous circuits. "
 this is what happens if I set cadence for phase noise simulation using the instructions given in the cadence Spectre manual.
I know... the instructions are for a 'normal' vco; but I was hoping that it would work for my injection locking case as well.
Question, as obvious it is by now :), how do we simulate the injection locked oscillator phase noise ?
Is there a way to conceal the periodic voltage source in the circuit so as not to piss the pss off ?
thanks,
calp.
  • VijaySM
    VijaySM over 11 years ago
    Hi Shanw,
    Thank you for your inputs. I have created a new thread and mentioned what I am trying to do.
    http://community.cadence.com/cadence_technology_forums/f/33/t/33109
    Looking forward to your suggestions,
    Vijay
