  2. RF Design
  3. How to change .tran options in Virtuoso
  • Subscribers 62
  • Views 15119
HamidKhatibi
HamidKhatibi over 12 years ago
Hi everybody
Virtuoso cannot find a DC solution for my extracted (Calibre) circuit. The message says that I46_node0, where I46 refers to my main circuit symbol in the testbench circuit, has no path to ground. However the same circuit has no problem when I use the "Schematic" instead of "Calibre". My circuit I46 has no net0 in it! Hence I cannot understand which node is responsible for this problem!
I thought that I may need to change "gmin" in order to help transient analysis. However, I could not find where I have to change it!
Can anybody help me with it? How to change gmin and how to find a referred net in a circuit which from a symbol view.
Hamid
    You didn't say which simulator you're using. Or version.
    If it's spectre, gmin is found under the Simulation->Options->Analog form.
