  2. RF Design
  3. Clarification regarding AM & PM component simulation in...
  • Subscribers 63
  • Views 6241
Clarification regarding AM & PM component simulation in PNOISE (particularly for Oscillator)
RFStuff
RFStuff over 12 years ago
Dear All,
I  simulated a simple LC oscillator noise ( PSS+PNOISE) at the oscillator output ( IC5141, .sub-version  12.1.0.402.isr5).
I have also saw  the topic "Explain the differences between the 4 noisetype settings for pnoise". But it could not answer what I want.
I used Shooting Method for PSS. I actually wanted to find the AM Noise & PM noise component separately. For total output noise I used PSS+PNOISE analysis. The noise power in db10 looks ok as it is matching the analysis. And it is a Single Sided PSD.
However, when I tried to plot AM noise component and PM Noise component separately I faced a really horrible experience. It is really confusing !!
Could anybody please clarify the following. It will be really helpful not only for me but also for many other designers.
1:-
First of all the plot form format in pnoise -source-modulated is very different form.
    a) Power is being plotted in absolute value?   why not in db10 like Pnoise ( is it because of IC5141 )
    b) dBV option is there unlike PNOISE form. Why ?
    c) USB, LSB, AM & PM
     What is USB:-
     is it total noise (AM+PM) in Fcenter + Fif   ?  ( is it Single sided or double sided PSD )
     What is LSB :-
     is it total noise in Fcenter - Fif   ?  ( is it Single sided or double sided PSD )
     What is AM:-
     Is it only AM noise component ?
    is it ( Single-Sided or Double Sided PSD ) As there is dbV I suspect it is all Single Sided PSD )  ?
    is it possible to plot AM Noise in Fcenter + Fif band & Fcenter - Fif band ?
 What is PM:-
  Is it only PM noise component ?
  Is it ( Single-Sided or Double Sided PSD ) ?
  Is it possible to plot AM Noise in Fcenter + Fif band & Fcenter - Fif band ?
2:-
When I plotted the AM noise ( I have captured it in the figure as AM-Noise_dBV.png ), It didn't match the analysis in the lower frequncy range.  I plotted in dBV as when I Plotted it gives me -ve value also  below 1MHz ( attached as AM-Noise-Power.png).
Beyond 10MHz it was matching with analysis. Also I am finding a NOTCH in the AM-PSD why is this ?
3:-
When I plotted the PM noise  ( I have captured it in the figure as PM-Noise_dBV.png ), itis exactly folllowing the total -power as drawn in pnoise analysis but with around 3-dB less
 Kind Regards,
  • RFStuff
     AM-Noise_dBV.png is attached here
  • RFStuff
    AM-Noise_Power..PNG is attached here
  • RFStuff
     PM-Noise-dBV.png Attached here
  • Tawna
    Tawna over 12 years ago
    Hi RF Stuff,
    This sort of thing should really be addressed by contacting Cadence Customer Support (http://support.cadence.com ) rather than on the forum.
    I cannot answer these questions at the moment (I have my "day job" to attend to!  <grin>) but I strongly recommend that you look at the MMSIM12.1.1 SpectreRF documentation on Cadence Online Support.  It is really thorough and explains a lot of these terms.
    A link to this is:
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=pubs;q=/spectreRF/spectreRF12.1.1/Chap3.html#hbnoise
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=pubs;q=/spectreRF/spectreRF12.1.1/Chap4.html#pnoise
    best regards,
    Tawna
