  2. RF Design
  3. Launching SP analysis with GoldenGate from ADE
  • Subscribers 63
  • Views 14504
Kabal
Kabal over 12 years ago
I did set up my GoldenGate environment, integrated it with Cadence and as a simulator instead of Spectre selected GoldenGate. I ran the simulation, I checked the output file, it all looked right, in other words simulation did perform well.
 However,  the Run Summary window on the bottom left shows "finished with errors" next to my Interactive.13 History Item. And I am not sure why? I am writing about it here because it clearly has something to do with Cadence Environment.
After simulation is done, the log file pops out, which is basically th goldengate output log file, I am attaching it here. There are some warnings etc, but no errors, then why does that "finished with errors" message show up next to a history Item in Cadence?
goldengate.zip
    Maybe it is something to do with the exit status of the simulator - it's really hard to know. I don't have access to Goldengate so can't test this.
    Given that the simulator is from Agilent, as is the ADE integration, it would be best to ask Agilent's customer support about this. They can contact us if further support is needed related to their integration in ADE.
    Kind Regards,
