  2. RF Design
  3. Plotting gm Vs. time from PSS simulation (6.1.5-64b.500...
  • Replies 13
  • Subscribers 63
  • Views 20703
Plotting gm Vs. time from PSS simulation (6.1.5-64b.500.11)
MicheleA
MicheleA over 12 years ago
Hi all,
yes...there is this support answer #11003524 which should address the topic.
I also learnt from Andrew some time ago about saving oppoints and/or specific info through a file and attaching it to the model libraries.
What I am experiencing now is that the method:
a) gives me the info out of a *tran*
b) gives me the info out of a *envlp_td*
c) for a *pss*, I get
1. a _constant_ value in the *pss_td* folder, if I use the shooting method (seems like a DCOP value)
2. nothing if I use the HB method
Just wondering whether that is the behavior to be expected, or shouldn't I get a (nice) plot of my wanted gm over a period, exactly like I get it for any other V/I in the circuit after a pss?
I seem to remember having done the same thing some 6 months ago and it worked fine..
Thanks for any help.
Michele
  • MicheleA
    So...I must be growing older since I do not remember replying to myself in the past ;-)
    Anyhow, I found out yesterday what the issue is. I was simulating using the 'High Performance Simulator -- APS'.
    For some reason - I am in contact with the Support for this - it looks like the stored gm is just a DC value.
    I had a glimpse yesterday and tried the same simulation with good ole Spectre and bam! My gm Vs. time was there!
    Happiness!
    Maybe this helps someone,
    Michele
    Michele,
    That sounds like a bug to me. This ought to work, so support should ensure that a CCR is filed to get this fixed.
    That said, I tried to reproduce it with MMSIM12.1 ISR14, and for me I get the gm value saved during shooting in the pss_td database (as a waveform) even when using APS. This isn't true with harmonic balance, but then again that doesn't surprise me - with harmonic balance it would need to solve the gm as a harmonic series and then convert it back into the time domain - and it only computes the voltages and currents as a harmonic series.
    Here's the netlist I used:
    // test of saving gm during a pss analysis
    model nch bsim4 type=n
    model pch bsim4 type=p
    MP1 (z a vdd vdd) pch w=2u l=0.5u
    MN1 (z a 0 0) nch w=1u l=0.5u
    Vz (a 0) vsource type=pulse period=40n width=20n rise=1n fall=1n val0=0 val1=1.5
    Vvdd (vdd 0) vsource type=dc dc=1.5
    save *:gm sigtype=dev devtype=bsim4
    tran tran stop=200n
    pss pss period=40n outputtype=all // harmonicbalance=yes
  • MicheleA
    Andrew,
    yes I just sent my netlist to the Support via our internal channel. Will keep you posted here anyways.
    I do not know which MMSIM version I am under (what's the command to see this?), just the Cadence version.
    I could source from 500.4 to 500.15 but all gave me this (with APS).
    By the way, I was under the impression that HB would not work for time rep of gm. Then why do you say 'harmonicbalance=yes' in your netlist?
    Michele
    Michele,
    Type "spectre -W" or look at the top of your spectre output log - it will tell you the subversion you're using.
    The harmonicbalance=yes in my netlist is commented out (it's preceded by // which is a comment).
  • MicheleA
    sub-version 12.1.0.272 it says.. M
    Surprised you're using the base MMSIM12.1 version - been quite a few hotfixes since then. However, with my netlist, that version works too - I get a waveform in the pss_td database for the gm.
    Perhaps you can check? Run "spectre invpss.scs" and open the results in ViVA. Maybe there's some subtle difference in your testcase.
    Of course I meant "spectre +aps invpss.scs".
  • MicheleA
    Andrew, maybe I should add that I am doing all this from ADEXL I will later try the following: 1 - save the netlist you provided above under invpss.scs 2 - run the command 'spectre +aps invpss.scs' 3 - open the results in ViVa (that's going to be a journey..never used the sim from cmd line ;-P) Will keep you posted, M
    I like to encourage people to live on the edge now and again ;-)
    In general I'd expect you to be running from ADE; obviously the benefit of a small command line example is that it's a bit easier to share in a forum like this (and I can throw it together in a few seconds).
    I look forward to hearing your findings!
  • MicheleA
    Thank you for fostering my growth Andrew ;-)
    ...And indeed, your netlist works like a charm! But what a crappy gm :-D
    I then tried to use ADE instead of ADEXL for my circuit, however the result is the same: I get a curve with Spectre only. APS gives a sort of DC value out.
    Same thing if I sim my circuit from the command line (now I'm a master :-))
    I also noted that the whole sim setup is waaay faster when using cmd line. Ok, the circuit is two transitors but I got the impression that the processes *before* actual simulation took a fraction of the time.
    Can you please point me to the help entries containing - possibly an overview - of topics like 'running Spectre from the command line' and directory structure...things like that.  Maybe the time has come for me to understand all this a little better.
    Michele
