  2. RF Design
  3. How can the calculator find a "x" according to a "y"?
  • Subscribers 63
  • Views 1592
xxgenerall
xxgenerall over 12 years ago
Simulation waveform is as follows.
In the output, I want to find the xvalue when yvalue=0.5. As is known, this can be done very easily in wavescan. If we want to print the xvalue directly after simulation, how to set the output in calculator?
Thanks a lot.
    cross(VT("/net3") 0.5)
    will do this. It defaults to giving you the first crossing point where the crossing happens in either direction.
  • xxgenerall
    Thank you, Mr. Andrew.
    ^_^
