  2. RF Design
  3. Parameter empty when using cds_srr function
  • Replies 8
  • Subscribers 64
  • Views 17007
mhawary85
mhawary85 over 11 years ago
 I have a problem in reading the simulation results using Matlab. The problem is that when I am trying to read multiple parameters, the first one i read it correct but after that all parameters returns zero in value.  The Matlab code i am using is the following:
clear
addpath /opt/cadence/installs/MMSIM131/tools.lnx86/spectre/matlab
simpath=sprintf('/home/malhawari/simulation/boost_conv/spectre/schematic/psf');
datalist=cds_srr(simpath);
vd = cds_srr(simpath, 'tran-tran', 'vd');
vg = cds_srr(simpath, 'tran-tran', 'vg');
The result is the following:
PSFversion: 1.00
tran-tran (tran).
finalTimeOP-info (info).
modelParameter-info (info).
element-info (info).
outputParameter-info (info).
designParamVals-info (info).
primitives-info.primitives (info.primitives).
subckts-info.subckts (info.subckts).
variables (design_variables).
vd =
    info: {'V'  'V'  'time'  's'}
    time: [7607x1 double]
       V: [7607x1 double]
 vg =
    time: 0
       V: 0
 Now if i flip the order of the vd and vg in the Matlab script where i read first vg and then vd i get the following
>> vg
vg =
       V: [7607x1 double]
 vd =
    time: 0
       V: NaN
This confirms the problem of reading only the first parameter in its correct way while other parameters are zero.
 BTW I am using MMSIM131 and IC616, also i tried MMSIM121 and IC615 but i got the same results!
Thank you in advance for your help!
Regards
Mohammad
    Mohammad,
    Any chance you could upload your psf directory (tarred and gzipped), if it is not too big? This is likely to be data dependent. I'll do some generic checks when I boot up in a while, but most likely I'd need to understand your data.
     Also, which Matlab version are you using (the important things are the Matlab and MMSIM versions, not the IC version in this case)?
  • mhawary85
    Dear Andrew,
    Thank you for your super fast response!
    Unfortunately, The file size is around 11MB and am not able to upload it here. As such, Please follow this link to download the psf file https://www.dropbox.com/sh/umr3vwea13clct0/YbkMBD8xwu
    The Matlab version I am using is 8.1.0.604 (2013a)
    Regards
    Mohammad
    Hi Mohammad,
    Thanks for the data. I reproduced the problem and then tried with a patch build of cds_srr, and that solved the problem. One of the issues we've had is that because of compiler restrictions for older versions of Matlab, we've not been able to build with newer versions of SRR (the simulation results reader package that's used inside this). In particular, your issue is probably caused by the fact that the waveforms are in PSF XL format - and I suspect that's why the older cds_srr builds can't cope with that.
    We're planning on getting the updated cds_srr released into a hotfix soon (this will be restricted to R2012a versions of Matlab onwards) - but if you could send me a PM via the forum with your email address, I can log a CCR on your behalf to push for this to happen sooner rather than later - and that way I can also send you the patched version which fixes the problem (it's an overlay for the MMSIM12.1 or MMSIM13.1 hierarchy).
  • mhawary85
    Dear Andrew, Thank you for figuring this out! My email address is : mohammad.alhawari@kustar.ac.ae What do you mean by PM :) Regards Mohammad
    Hi Mohammad,
    I was just trying to avoid you needing to post your email address in a public forum. The "PM" was a Private Message, which you can get to via the Contact button at the top of the post.
    Anyway, done now - I've sent you (via hightail) the patch for cds_srr.
  • mhawary85
    Dear Andrew,
    Its working now perfectly!!
    Thanks for your great efforts!
    Regards
    Mohammad
  • ProfWalker
    ProfWalker over 11 years ago
    Hello!
    Has there been any progress on this issue?  I'm seeing the same behavior with a number of MMSIM versions all the way back to 7.1-ish.
    -Ross
    Ross,
    Yes, it was fixed in an MMSIM13.1 subversion (MMSIM13.1 ISR7 and later). I just tried it out in MMSIM13.1 ISR8 (13.1.1.117.isr8), and it worked fine.
    So no need for the patch any more.
    Kind Regards,
