  2. RF Design
  3. Complex filter : Image Reject Ratio (IRR) calculation
  • Subscribers 63
  • Views 15432
lahsivece
lahsivece over 11 years ago
Hi ,
How do I simulate IRR of complex filter.  ? ( A transient simulation of an IQ mixer followed by a complex filter and then look at dft of the output waveforms is one way )
Is there a cadence documentation for the same ?
Vishal
    Vishal,
    I think I would probably do this with pss+pxf (or hb+hbnoise with "Do noise" turned off). The pss would be used to analyse a period of the LO frequency of the mixer, and then you'd run the pxf specifying the output and output frequency, and you could plot the two input sidebands - the desired as well as the image - and the IRR would be the ratio of the two. That would be quite efficient to simulate.
  • lahsivece
    Thanks Andrew ,
    A pss+pac analysis also gives the similar results .
    Vishal
