  2. RF Design
  3. Error Vector Magnitude (EVM) simulation problem in IC61...
  • Subscribers 63
  • Views 16103
Error Vector Magnitude (EVM) simulation problem in IC615
Alex Vasjanov
Alex Vasjanov over 11 years ago
 Hello, cadence community,
I've stumbled upon a problem with power amplifier EVM evaluation - EVM is out of adequate bounds. At first I thought that the PA is faulty, but then I decided to create a simple DUT circuit - a resistor. This way the magnitude will decrease while the phase should stay the same.
I've attached the schematic and the EVM output plot.
Everthing is done strictly using MMSIM PA tutorial in IC615 (SpectreRF Workshop Power Amplifier Design Using SpectreRF MMSIM 12.1).
The standart of interest is 802.11a (but the calculations are wrong with 802.11n as well). The PWL files for I and Q channels were generated using 802.11a_signal_generator following the guide in the above mentioned document. The carrier frequency is 5GHz, rolloff factor is 0.23, bandwidth is 1.2288MH... - every setting in the spectre state is the same as in the tutorial.
So the question would be - is this a known bug with EVM estimation or is there something wrong with my configuration? Has anyone done successfull EVM measurements and if so - please share your knowledge. There is one suspicion that the 802.11a_signal_generator creates a faulty signal but I don't know how to check it. I've tried to use the cdma PWL files in Cadence rfLib, but get the same results (EVM value is not the same as in the picture above bus is inadequate).
Aleksandr,
  • Tawna
    Tawna over 11 years ago
    Hi Aleksandr,
    I believe this question would be best handled by Customer Support.
    Unfortunately, I don't have time to look into this right now.
    It is always important to list the exact IC and MMSIM subversion that you are using.  This can be found by typing in an xterm:
    virtuoso -W
    and
    spectre -W
  • Alex Vasjanov
     Hello, Tawna,
    I'm using  the following MMSIM and Virtuoso versions:
    •  virtuoso version 6.1.5-64b
    •  virtuoso sub-version  IC6.1.5-64b.500.4
    • spectre sub-version  12.1.0.317.isr2
    And apologies for the non attached schematic in the original post. It should be visible now.
    Aleksandr.
