  2. RF Design
  3. Plot issues in IC 615
  • Subscribers 63
  • Views 15784
radiowaves
radiowaves over 11 years ago
 I have upgraded to IC 615 from IC 613. But I am facing problems:
1. In spectre RF when I do s parameter simulation and try to plot gain circles (Ga,Gp etc) I get nothing. Noise circles work well. I can plot the gain curves wrt frequency though which shows data is available.
 2. When I plot voltage conversion gain using pac then I get bar plot by default instead of solid line curve. Also in some plots I get in powers of ten form. How can I customize the plot?
    I'm surprised. Which subversion of IC615 are you using? Type: getVersion(t) in the CIW to find out, or use Help->About in the CIW or other windows to find out.
    The second issue might depend on the simulator version used too, so which simulator version are you using? This should appear at the top of the spectre.out log file in ADE.
  • radiowaves
    I am using IC6.1.5-64b.500.1 and my simulator version is 10.1.1.296.isr18 64 bit
    The ViVA graph was completely re-implemented in IC615, and particularly RF support was a little limited right at the beginning - you're using the very first hotfix. I would really recommend moving to either IC615 ISR17 (6.1.5.500.17) or IC616 ISR5. I think it is highly likely the issue you are seeing is solved in a later version.
  • radiowaves
    The issue got resolved with IC616. Thank you very much!
    I have 1 more problem. When I try opening some layout created  in IC 615 using IC 616 then it says:
    *Error* append: argument #2 should be a list -t
    Do you know what is it?
    That error is a pretty non-descript SKILL error caused by something doing append(someArg t) in SKILL code. Could be anywhere. You could try doing:
    sstatus(errsetTrace t)
    _stacktrace=50
    tracelength=tracelevel=50
    and then opening the layout. I'd be pretty surprised if it was anything to do with it being IC615 layout - but maybe you have some customization which is looking for something specific in the layout and not handling things well? It might be Cadence code, but I've not seen this before (with these symptoms, at least).
  • radiowaves
    The issue is resolved. Highly appreciate your help.
    Regards
