  2. RF Design
  3. Group noise contributors
  • Replies 13
  • Subscribers 66
  • Views 24864
seppo2
seppo2 over 12 years ago
Hi guys,
When you do print->noise summary after a noise sim or pnoise sim, is there a way to group noise sources together; either by block or device?
In the case of an extracted list, if you have a number of fingers for a transistor, the noise simulation gets broken down into each individual finger. It's difficult to read what a device contribution is if it is broken down into 100 individual sources of noise!
 The same idea would be handy to work out the total contribution from a block.
 Perhaps it is about time you update the noise summary feature in ADE... :)
Cheers,
Seb
PS: While I am at it, could you also include noise summaries for input referred noise!
    Peter,
    No, it's in all releases from IC6.1.6.500.7 onwards. I just tried it with ISR8. However, there is also a dependency on which MMSIM version you're using. As I mentioned in an earlier post in the thread, this requires MMSIM13.1 ISR7 or later. Check in the spectre.out log file to see what version you're running (the requirement is at least sub-version  13.1.1.078.isr7).
  • Orko
    Orko over 11 years ago
    Thanks for help. It works.
  • Frank Wiedmann
    Frank Wiedmann over 11 years ago
    The request to do this cleanly has been submitted as CCR 1474143. Anyone who would also like to request this should ask Cadence Customer Support for a duplicate of this CCR on his behalf.
