  2. RF Design
  3. Assura LVS is negelecting shorted/opened device in the ...
  • Subscribers 63
  • Views 526
Assura LVS is negelecting shorted/opened device in the schematic
RFStuff
RFStuff over 11 years ago
Dear All,
We are using a new process. We found that  Assura LVS is negelecting shorted/opened device in the schematic. We are using Assura latest version.
I saw the compare.cdl file. I saw   filterOptions = "XZ" in the file.
Also I saw the code as below:-
 DEV_list = list( "kxres_m0" "l1res_m0" "nwres_m0" "opndres_m0" "silres_m0" "opppcres_m0" "oprppres_m0" "oprrpres_m0" "kxres_m1" "l1res_m1" "nwres_m1" "opndres_m1" "silres_m1" "opppcres_m1" "oprppres_m1" "oprrpres_m1" )
if( !avSwitch( "layout_compare_filters_only" ) then
    foreach( FET_dev DEV_list
      filter(FET_dev  sch  filterOptions ignore("G") )
    ) ; end foreach FET_dev
  ) ; end avSwitch
I have following doubt/confusions. Can  anbody please calrify them:-
1:-
  I think filterOptions = "XZ" applied to all  devices but overridden by the filter( ) command. Am I right ?
2:-
Where I can set/change the values of avSwitch ? or there is NO option as such ?
3:-
 If I comment the  filterOptions = "XZ", what will happen to filter(FET_dev  sch  filterOptions ignore("G") ) in the above code ?
4:-
 If I comment the  filterOptions = "XZ", what will happen to filter(FET_dev  sch  filterOptions  )  ?
Kind Regards,
