  2. RF Design
  3. Problem in running RFworkshop examples
  • Subscribers 63
  • Views 15261
radiowaves
radiowaves over 11 years ago
I tried running some examples in RFworkshop. But while running simulation in ADE using readymade saved states I get the following error:
 ERROR (SPECTRE-15): Unable to run circuit preprocessor (/lib/cpp).
        No such file or directory.
Please help in fixing this.
Thanks!
  • Tawna
    Tawna over 11 years ago
    According to http://support.cadence.com Article 1841055, this error means that Spectre couldn't find the c pre-processor file cpp at /lib/cpp.
    This can be resolved by reinstalling the operating system component which will install all the c language utilities, including the c pre-processor cpp that the Spectre simulator requires.
    On RHEL machines, this comes from the "cpp" RPM file:
    UNIX> rpm -q -f /lib/cpp
    cpp-4.4.5-6.el6.x86_64
    UNIX> rpm -q -f /usr/bin/cpp
    Your version number may vary...
  • radiowaves
    Thanks!!
