  2. RF Design
  3. Input impedance calculation using DFT for Radio Frequen...
  • Subscribers 63
  • Views 15423
Input impedance calculation using DFT for Radio Frequency
MohanB
MohanB over 7 years ago
Hi
I am trying to find the input imepdance of an RF rectifier circuit by using FFT in cadence. The equation I'm using is
                      Zin = DFT(Voltage)/DFT(Current) at the required frequency.
However, after evaluation cadence gives me only the magnitude of the impedance Zin.
How can I get both the real and imaginary parts after the above computation?
    The result of the dft() function in the Virtuoso Visualization and Analysis calculator (ViVA)  (assuming you're talking about the Virtuoso tools - you just said "in cadence" - there's no tool called "cadence") are complex values versus frequency. So the expression you describe above is also complex versus frequency.
    If you plot it, it automatically plots the magnitude, but you can use the real() or imag() functions to get the real or imaginary parts - you can also use the phase, phaseDeg, phaseRad, phaseDegUnwrapped etc functions to get the phase.
  • MohanB
    MohanB over 7 years ago in reply to Andrew Beckett
    Thanks Andrew
