  2. RF Design
  3. How to define port in cadence which has a impedance value...
  • Subscribers 63
  • Views 18193
How to define port in cadence which has a impedance value that is frequency dependent
AtaV
AtaV over 7 years ago
Hi Everyone,
I am trying to use a port with complex value as a output termination in SP simulation of cadence. For example output port impedance value is 1/(2*pi*freq*C) which is also frequency dependent. Is there any idea how to do this in cadence? Thanks in advance.
    Not as far as I know. Please contact customer support.
  • Tawna
    Tawna over 7 years ago
    I agree with Andrew.  You need to contact Customer Support and file an enhancement CCR.
    You can specify an impedance (resistance and reactance parameters) in the port.  It is not frequency dependent.
    From Spectre Circuit Simulator and Accelerated Parallel Simulator RF Analysis in ADE Explorer User Guide -- 8 - Terminating the Port
    Resistance
    The reference resistance of the system. The value must be a real number, but not 0. The default value is 50 ohms. This applies for all analyses. Note that the resistance and reactance can be set individually for each harmonic in harmonic balance large-signal analyses only. For more information, refer to Using the Harmonic Port with Harmonic Balance .
    Reactance
    The imaginary part of impedance is used for harmonic balance large and small-signal analyses, and for the ac, noise, xf, sens, stb, pz, and sp analyses. The reactance is not used for the dc, transient, and shooting-based large and small-signal analyses. The value must be a real number. The default is zero ohms. Note that the resistance and reactance can be set individually for each harmonic in harmonic balance large-signal analyses only. For more information, refer to Using the Harmonic Port with Harmonic Balance .
