  2. RF Design
  3. ENVLP Anaylsis Questions
  • Subscribers 63
  • Views 15336
YanivL
YanivL over 6 years ago
I've few question regarding ENVLP analysis and wireless simulations within it.
1) Where can I find the actual values of important parameters after the analysis is finished..It seems that part of them are in the netlist file and part of them are in the Spectre log, but some of them are missing...for example - modulationbw, fmspeedup... etc
2) In rflib\lte...is there an option to run Category M1 uplink signals? I saw legacy LTE and NbioT only. Are there any future releases that will expand the LTE signals?
3) The Post processing of wireless spectrum (including plots) takes a lot of time and sometimes the spectrum is computed incorrect (for example, in narrow-band signals). Is there an option to export the envelope data (time domain), and analyse in Matlab for example?
BR
Yaniv
    Yaniv,
    Please contact customer support. It would be helpful to know which IC and SPECTRE version you're using too (when contacting customer support). I see you tried yesterday to contact customer support via email, but that's no longer accepted - you need to log the case via our web site support.cadence.com
  • YanivL
    YanivL over 6 years ago in reply to Andrew Beckett
    Cases seems to be for SW bugs...I'm more of asking technical questions. Is it the correct platform?
    Yaniv
    Andrew Beckett over 6 years ago in reply to YanivL
    Yaniv,
    No, customer support cases are for usage advice, problems that need solving and enhancements and bugs. Not sure where you got the idea that they were for bugs only. This forum is more for when an issue can be quickly solved by the community rather than needing more lengthy investigation by an application engineer.
    in this specific question I think (and I’ve not had a chance to check as I’ve been travelling with work), that your request will need an enhancement. That definitely will need to go via customer support and even if it doesn’t it’s likely to need an application engineer to do some checking and how to do this (I don’t know the answer off the top of my head).
    Kind Regards,
