  2. RF Design
  3. BSIM4 import into AWR
  • Subscribers 64
  • Views 18400
ChrisG04
ChrisG04 over 5 years ago
I am trying to import a cadence BSIM 4.4 model file (.scs) into AWR from a foundry PDK (built for Spectre RF). The parsing and symbol creation go through fine but it comes up with a load of "Variable not valid" errors. Some examples below:
"toxe_n33 - Equation Error: Variable 'dthkox@' is not valid"
Same for: mc_gl_f@, cnr_toxd@, dthkox@, cnr_n33@, etc...
I expect the Cadence environment takes care of these somehow. Wondered if anyone knows a solution for this or has come across this before.
AWR version I am using is:13.02r build 8379 Rev1 (104876) (64-bit)
Many Thanks,
Chris.
  • GraemeR
    GraemeR over 5 years ago
    Hi Chris,
    It's possible to import spectre models into MWO by importing them as a spectre netlist.   When you do so, you need to ensure that you are importing all of the model as most model files you find in a PDK will be referencing other files to get things like corner and/or mismatch info and all necessary parameters need to be clearly defined for it to simulate.
    To actually use the model in an MWO schematic you need to call it from a simple netlist of the format:
    simulator lang=spectre
    inline subckt devicename (D G S B)
        parameters w=5u l=0.25u
        M0 D G S B mymodelname w=w l=l
    ends devicename
    model mymodelname bsim4
    +type    = n
    +version = 4.4
    +lmin    = 2.5e-7
    +noic    = 1.4e-10
    This will give you a device you can place on a schematic which is scalable for w & l.    The spectre netlist parser in MWO is fairly basic so if there are special characters in the parameter names you may need to do some manual cleanup before it'll import and simulate correctly.
    Graeme
  • ChrisG04
    ChrisG04 over 5 years ago in reply to GraemeR
    Hi Graeme,
    Many thanks for the reply, much appreciated.
    I have used this template and imported the BSIM variables manually and converted all the complex equations to values and it is working now (at least the DC part). Yet to test the AC and nonlinear HB but at least the sim is running now without errors.
    Only thing is that I am getting a couple of warnings: "Source conductance reset to 1.0E3mho. (BSIM4!_S1_nfet33)", and "Drain conductance …." (where nfet33 is my devicename)
    Doesn't make much sense as when I change the w, the Drain current seems to scale correctly. Just wondering if you know what these warnings refer to?
    Best Regards,
    Chris.
  • GraemeR
    GraemeR over 5 years ago in reply to ChrisG04
    Hi Chris,
    I wouldn't worry about that warning, these relate to DC operating points calculated by APLAC representing the internal terminal resistance.  If this isn't being calculated from the given parameter set then forcing a small resistance aids convergence.
    Graeme
  • ChrisG04
    Many thanks again Graeme. Yes this works without warnings now. I have created three internal pins 11, 21, 31 before the BSIM model and placed an inductor/resistor circuit in these.
    Below is the code (for anyone else trying this).
    Best Regards,
    Chris.
    inline subckt mynfet ( d g s b )
    parameters w=1.0e-6 l=0.25e-6
    lg  (g 20 ) inductor l=1.000e-15
    rg  (20 21 ) resistor r=1e-6
    ldrain ( d 13 ) inductor l=1.000e-15
    rdrain ( 13 11 )  resistor r=1e-6
    lsource ( s 33 ) inductor l=1.000e-15
    rsource ( 33 31 )  resistor r=1e-6
    mynfet ( 11 21 31 b ) mybsim l=l w=w
    model mybsim bsim3v3 version=3.2 type=n  capmod=2.0000e+00 \
     mobmod=1.0000e+00  nqsmod=0.0000e+00  noimod=3 \
        nch=2.3100e+17 vth0=4.6550e-01 \
    ....(REST OF BSIM DATA)
    ends mynfet
