  2. Allegro X Scripting - TCL
  3. Checking Menu Item states from tcl script
  • State Verified Answer
  • Subscribers 13
  • Views 1543
HH202501061832
HH202501061832 7 months ago
I'm writing a script that will run a bunch of commands at startup, including setting some user-defined hotkeys and setting up some menu item state to a default value,
Say I'm trying to set "Grid References" to the "unchecked" state at startup. How can i do that in tcl?
I can toggle it by using: Menu "View::Grid References"
 But with that, i can't force it to be unchecked, i can just toggle it,
Is there a way for me to check the state of the menu item before applying the toggle event?
It might be something simple such as a command that i missed, i'm not super familiar with the command structure here, just trying out a few things to learn them.
Thank you
    0 Andrew Beckett 7 months ago
    What tool are you using here? I suspect you’re posting in the wrong place because Virtuoso doesn’t have a menu like that and it wouldn’t be set in TCL anyway.
  • HH202501061832
    0 HH202501061832 7 months ago in reply to Andrew Beckett
    Oh, I'm using Orcad Capture CIS. I guess i am in the wrong section. Could you suggest where this could be posted? Thank you
    0 Andrew Beckett 7 months ago in reply to HH202501061832
    I moved it to one of the Orcad forums.
  • CadAP
    +1 CadAP 6 months ago
     HH20250106183
    You can use below command to check the status and enable the "Grid References" value page wise.
    GetGridRefDisplayed(status) : returns int
    Class : DboPage(DboBaseObject):
    Parameters:
    status: DboState &
    SetGridRefDisplayed(bVal) : returns DboState
    Parameters:
    bVal: int
    Step to get page grid references
    1. Open a page
    2. Get Active page DBid using "GetSelectedPMITems"
    3.Type [GetSelectedPMITems] GetGridRefDisplayed [DboState]--> It will return 1 0r 0 based on enabled disabled status.
    Hope it helps.
    • Vote Up +2 Vote Down
  • HH202501061832
    0 HH202501061832 6 months ago in reply to CadAP
    Thank you, Helped a bunch.
    Worth to note that those functions are defined as DboPage_GetGridRefDisplayed and DboPage_SetGridRefDisplayed in (at least) my version of Capture CIS, different from the tcl extension file that is provided with the software.
    My code looks like the following now, if there is a need to have the Grid References turned off at startup (I did it because my zooming was messing up when it is ON):
    set activePage [GetSelectedPMItems]
    set lStatus [DboState]
    set return_state [DboPage_GetGridRefDisplayed $activePage $lStatus]
    if {$return_state == 1} {
         DboPage_SetGridRefDisplayed $activePage 0
