  2. OrCAD X Presto PCB
  3. Opening the Constraints panel without docking it into the...
  • Subscribers 16
  • Views 1253
Opening the Constraints panel without docking it into the tool makes it useless.
DG202504226528
DG202504226528 6 months ago
Just  a little FYI.  I was using the Constraints panel tab last week in Presto and it was working fine... then this week it wasn't working.
Seems like you need to dock it into Presto if this happens and it'll start working again.
Has anyone else found any quirks like this in the tool?  I wouldn't mind running a list of Presto quirks and work arounds.
Danny
  • mahimag
    mahimag 6 months ago
    Hello DG202504226528 , Can you share which version and hotfix for Presto you are working on?  Also can you share more on what went wrong when it is not working?
  • passedpawn
    passedpawn 4 months ago
    I've got a giant list of Presto bugs, quirks, workarounds.  Instead of posting the whole list, I've considered creating a thread here for each one of them.  That way, a unique discussion could happen for each item.  But always busy...
