  2. Allegro X APD
  3. Degassing with APD+
  • Replies 25
  • Subscribers 111
  • Views 42470
Degassing with APD+
PCBTech
PCBTech over 4 years ago
Degassing, also called outgassing, is a common feature in IC package designs. Degassing is a process where you perforate power planes, voltage planes, and filled shapes in your design. Degassing holes let the gas escape from beneath the metal during manufacturing of the substrate.
Reasons to go for degassing:
  • Prevents forming of gas bubbles under the metal (Otherwise, it would cause the surface of the metal to become uneven.)
  • Lowers the density of metal in a region or across an entire layer of your design
  • Improves the vacuum-lamination and pattern-plating manufacturing processes
The degassing feature in Allegro Package Designer Plus is an automated process where you can specify the details of the perforation array pattern. This generates the exact placement of voids across the entire shape. The tool does not create a void in the pattern if, in doing so, it violates any of the spacing or manufacturing requirements for degassing.
Users can also set layer-based parameters for degassing. This feature has the ability to define degassing per layer. It provides a quick way to set up layer-based degassing parameters both at the hierarchical level and individual level.
Allegro Package Designer Plus with the Silicon Layout option provides the Advanced Shape Degassing command in the Si Layout menu. This command uses the new data model. It provides significant memory and file size reduction, and speeds up overall performance.
You can also use the Off-Grid Degassing Holes command to add holes for metal areas where regular degassing pattern and matrix-based holes cannot be added due to conflicts with the routing, teardrops, vias, small metal areas, and shape edges.
Team PCBTech
Cadence Design Systems
  • masamasa
    masamasa over 2 years ago in reply to CH202410218528 +3
    after u generate the degassing holes, u can move or remove them individually by changing the general edit to the shape edit, selecting voids/cavities in the find filter and right mouse button has move…
  • masamasa
    masamasa over 4 years ago +1
    unfortunately, i do not use this function as i can not delete one single degassing hole after degassing holes are placed with this function.
  • mahimag
    mahimag over 4 years ago in reply to masamasa +1
    You can delete or move single degassing hole using the shape edit application mode. From the Find tab, select only Voids/Cavities. Select a degassing hole on the board and click RMB to Delete or Move.
  • Brandy Dorsey
    Brandy Dorsey over 4 years ago in reply to masamasa
    I have the same situation as you
    dinosaur game
  • bertumi
    bertumi over 2 years ago in reply to masamasa
    this is a great info. this would save me a lot of time
    geometry dash subzero
  • NadiaEira
    NadiaEira over 2 years ago in reply to masamasa
    Thank you both. I was having the same problem and didn't know how to solve it until I read this article.
    cookie clicker
  • CH202410218528
    CH202410218528 over 2 years ago in reply to masamasa
    I'm in the same boat as you.
    escape road
  • CH202410218528
    That's unfortunate, I haven't used that function before so I'm not sure how to help with deleting a single degassing hole after they've been placed.
    escape road
