  2. Allegro X APD
  3. Degassing with APD+
  • Replies 25
  • Subscribers 111
  • Views 42486
Degassing with APD+
PCBTech
PCBTech over 4 years ago
Degassing, also called outgassing, is a common feature in IC package designs. Degassing is a process where you perforate power planes, voltage planes, and filled shapes in your design. Degassing holes let the gas escape from beneath the metal during manufacturing of the substrate.
Reasons to go for degassing:
  • Prevents forming of gas bubbles under the metal (Otherwise, it would cause the surface of the metal to become uneven.)
  • Lowers the density of metal in a region or across an entire layer of your design
  • Improves the vacuum-lamination and pattern-plating manufacturing processes
The degassing feature in Allegro Package Designer Plus is an automated process where you can specify the details of the perforation array pattern. This generates the exact placement of voids across the entire shape. The tool does not create a void in the pattern if, in doing so, it violates any of the spacing or manufacturing requirements for degassing.
Users can also set layer-based parameters for degassing. This feature has the ability to define degassing per layer. It provides a quick way to set up layer-based degassing parameters both at the hierarchical level and individual level.
Allegro Package Designer Plus with the Silicon Layout option provides the Advanced Shape Degassing command in the Si Layout menu. This command uses the new data model. It provides significant memory and file size reduction, and speeds up overall performance.
You can also use the Off-Grid Degassing Holes command to add holes for metal areas where regular degassing pattern and matrix-based holes cannot be added due to conflicts with the routing, teardrops, vias, small metal areas, and shape edges.
Team PCBTech
Cadence Design Systems
  • masamasa
    masamasa over 2 years ago in reply to CH202410218528 +3
    after u generate the degassing holes, u can move or remove them individually by changing the general edit to the shape edit, selecting voids/cavities in the find filter and right mouse button has move…
  • masamasa
    masamasa over 4 years ago +1
    unfortunately, i do not use this function as i can not delete one single degassing hole after degassing holes are placed with this function.
  • mahimag
    mahimag over 4 years ago in reply to masamasa +1
    You can delete or move single degassing hole using the shape edit application mode. From the Find tab, select only Voids/Cavities. Select a degassing hole on the board and click RMB to Delete or Move.
  • zpofrp
    zpofrp over 1 year ago in reply to mahimag
    Can you share the command to delete degassing hole,because i have many degassing holes need to deleted.
  • masamasa
    masamasa over 1 year ago in reply to zpofrp
    in the shape edit mode, u turn on "void/cavities" in the find filter.
    then u select degassing hole u would like to delete.
    then u click "delete" on the menu with the right mouse botton.
    regards
    masa
  • zpofrp
    zpofrp over 1 year ago in reply to masamasa
    I only delete the hole one by one. if u selcet many holes, u don't RBM to select Delete.
  • JL202504145836
    JL202504145836 over 1 year ago
    Degassing is crucial for IC package integrity, preventing uneven metal surfaces. Think of it like carefully avoiding obstacles in the [url=https://dinosaurgamefree.com/]Dinosaur Game[/url], ensuring a smooth run. This process, using perforation patterns in Allegro Package Designer Plus, lets gas escape during manufacturing. It lowers metal density and improves lamination, avoiding violations of spacing or manufacturing rules. Properly implemented degassing ensures a robust and reliable final product.
  • Amanday
    Amanday over 1 year ago in reply to Brandy Dorsey
    Have you solved it yet?
