  2. Allegro X Capture CIS
  3. Replace off-page connector by Hierarchical Port - Allegro...
  • State Verified Answer
  • Replies 8
  • Subscribers 51
  • Views 10567
Replace off-page connector by Hierarchical Port - Allegro Design Entry CIS 16.6
Bala1
Bala1 over 12 years ago
I've schematics with 1000s of off-page connector, i wanted to replace all the off-page connectors in the design with Hierarchical port connection. I'm in the process of changing exisitng complex design into Hierarchical compliance design so that any section shall be reused.
I tried to replace the design cache of off page connector into Hierarchical port, but i could not do it due to property mismatch (offpage/Hierarchical port).
If you know anyother option to do this instead of doing one by one, please share how to replace it.
Thanks in advance..
  • HwMagician
    0 HwMagician over 6 years ago in reply to Bala1
    Hi.  I added the CoolEditBox to Capture 17.4.  I put all of the files in the capAutoload folder.  I can see the names of the scripts in the window after I select a component and press "more".
    However, al the selections are grayed out.  I can't chose any of them.  What am I doing wrong?
  • steve
    0 steve over 6 years ago in reply to HwMagician
    Try selecting off page connectors, or a group of wires or a port. This will only appear if you have items you can actually apply the app to.
  • David George
    0 David George over 5 years ago in reply to steve
    I am using CoolEditBox toolkit more than 3 years without any issue. but we are planning to move the library (off page connector and port) used my CooleditBox to central location is that possible to change script where to look for library file ?
