  2. Allegro X Capture CIS
  3. Schematic Symbols: How to hide pins on 17.2 S057
  • Replies 7
  • Subscribers 54
  • Views 27498
JFuoco
JFuoco over 7 years ago
It used to be simple to hide un-used pins in a package, following this guide: Connection Symbol Properties
  1. Optional: Setup Pack Short for connected pins.
  2. View -> Package
  3. Edit -> Properties
  4. [x] pins to ignore (hide)
But now it's not that easy:
I set up the pack short (1-3, 2-4):
View package, but then I can't select Edit -> Properties (greyed out):
Did the process change now?
The component in question is a fuse clip (https://www.littelfuse.com/~/media/electronics/datasheets/fuse_clips/littelfuse_fuse_clip_100_445_030_520_datasheet.pdf.pdf) and I'm trying to short + hide the pins as shown here... But curious the new process in general:
  • nitin
    nitin over 7 years ago in reply to excellon1 +1
    Hi, the Pin visibility can be toggled only for Power" type pins. If your pin is of type power the drop down becomes enabled and one can toggle the visibility for power pins. see snapshot below. This…
  • Lock2002
    0 Lock2002 over 6 years ago in reply to CadAce2K
    I realize the original post is 7 months old, but are all of these properties added to the schematic symbol because you don't have a CIS database?
  • DavidH172
    0 DavidH172 over 5 years ago in reply to nitin
    In version 17.4, Pin Ignore also removes it from the netlist.  What is the point of that?
