  2. Allegro X Capture CIS
  3. Orcad Capture Smart Pdf Pin Number Issue
  • Replies 10
  • Subscribers 53
  • Views 19669
Bruce Sun
Bruce Sun over 6 years ago
I generated a pdf file for the schematic but the pin numbers of a part(D2) are missing in the pdf file. But the pin numbers for other parts(like D1) are correctly shown as expected.
  • steve
    0 steve over 6 years ago in reply to CHAITRA B K
    Yes it is smart. Look at the bookmarks where you'll get a list of all the nets or use CTRL+F and then type the netname you are after. Very Smart!!!!
  • CHAITRA B K
    0 CHAITRA B K over 6 years ago in reply to steve
    Thanks for your reply.
    I am not getting the option like this --------File - Export - PDF.....
    Please find the below image
  • steve
    So looks like you are using 16.6 which is quite an old version. Make sure it is up to date in regard to the latest version of 16.6 (Help - About and the number should be 16.6-2015 S086) then go to Accessories - Cadence Tcl/Tk Utilities - Utilities then choose PDF Export and launch. You'll need either Ghostscript or Acrobat Distiller for this process to work.
  • CHAITRA B K
    Thank you steve i got it
  • thomas kin
    0 thomas kin over 5 years ago in reply to redwire
    Read about 'Pin designators / names are always visible in schematic' ... Devices" library don't show this behaviour, there I can turn on and off the ... pins for this reason although it is acceptable to hide pin numbers and names
