  2. Allegro X Capture CIS
  3. Unable to create simulation profile without crashing
  • Replies 8
  • Subscribers 51
  • Views 24351
krakos
krakos over 6 years ago
Whenever I try to create a new simulation profile in Allegro Design Entry CIS v17.4-2019 the entire program crashes with the below error message. This occurs with even a new, blank schematic. I don't get to the point where I can even see any simulation options. I have tried to repair the installation and I still have this error. Please help.
Kyle
  • krakos
    krakos over 6 years ago in reply to AvengerThanos +1
    Thanks for the follow-up suggestions. The issue appears with all designs (old and new ones from scratch). I was in contact with Cadence support and they told me to do the following which eventually worked…
  • krakos
    0 krakos over 6 years ago in reply to AvengerThanos
    yes
  • meza62831
    0 meza62831 over 6 years ago in reply to krakos
    Hi Krakos,
    I´m having the same problem and using this procedure help to make it work couple of times, but the problem appeared again. Every time it appeared I had to do the whole procedure again and again.
    I´m not sure what is causing it, and I don´t know if you know what cause it in you situation, some info that could help me out.
  • DavidH172
    0 DavidH172 over 5 years ago in reply to krakos
    This also happened to me.  I found that the pspice.ini file was corrupted.  I manually removed the corruption and that fixed it.
