  2. Allegro X Capture CIS
  3. Defining Custom Shortcut Keys on OrCAD Capture CIS v17....
  • State Suggested Answer
  • Replies 7
  • Answers 1
  • Subscribers 53
  • Views 22034
Defining Custom Shortcut Keys on OrCAD Capture CIS v17.2
Gelo M
Gelo M over 5 years ago
Good day!
I'm currently using Cadence OrCAD Capture v.17.2.
Is there a way to bind custom keyboard shortcuts to functions accessible through mouse clicks?
For instance, I'd like to map "Signals" as shown below to, say, CTRL + ALT + S:
Signals
Thanks in advance!
  • tennywhy
    tennywhy over 5 years ago in reply to Gelo M +2
    1. you should rename the file shortcut.tcl. and put it in capautoload directory 2. you should turn on the command display in command window use follow command , then you will see the menucommand when…
  • tennywhy
    tennywhy over 5 years ago +1
    i have do it , my be you could reference code below ########################################### # asume shortcut key set as Ctrl+W ########################################## proc shortcutSetInit {…
  • CadAP
    CadAP over 2 years ago in reply to Gelo M +1 suggested
    Look like you have you have namespace shortcutset but you have not used for proc shortcut_RegsiterAction? Try porc shoructset:: shortcut_RegsiterAction also for shortcut_Enbale pass try to pass argument…
  • CadAP
    0 CadAP over 2 years ago in reply to Gelo M
    Look like you have you have namespace shortcutset but you have not used for proc shortcut_RegsiterAction? Try porc shoructset::shortcut_RegsiterAction also for shortcut_Enbale pass try to pass argument "args" only.
  • Bilal S
    0 Bilal S over 1 year ago in reply to CadAP
    I have made this piece of code for setting shortcut key for signals:
    # assume shortcut key set as Ctrl+Alt+Q
    namespace eval ::capMenuUtil {
    namespace export shortcutSetInit
    namespace export shortCutSetAll
    namespace export shortcut_RegisterActions
    namespace export shortcut_Enabler
    proc ::capMenuUtil::shortcutSetInit {} {
    set shortCutArray {
    {"Signals" "Ctrl+Alt+Q" {MenuCommand "14844"}}
    shortCutSetAll $shortCutArray
    proc ::capMenuUtil::shortCutSetAll {lshortCutArray} {
    set shortCutArray $lshortCutArray
    set shortCutLength [llength $shortCutArray]
    for {set i 0} {$i < $shortCutLength} {incr i} {
    set shortCutElement [lindex $shortCutArray $i]
    shortcut_RegisterActions $shortCutElement
    proc ::capMenuUtil::shortcut_RegisterActions {shortCutElement} {
    set shortcutName [lindex $shortCutElement 0]
    set shortCut [lindex $shortCutElement 1]
    set commandNumber [lindex $shortCutElement 2]
    RegisterAction $shortcutName "::capMenuUtil::shortcut_Enabler" \
    $shortCut $commandNumber "Schematic"
    proc ::capMenuUtil::shortcut_Enabler {} {
    set lEnableDS 0
    set lSelObjs [GetSelectedObjects]
    if {[llength $lSelObjs] == 1} {
    set lObj [lindex $lSelObjs 0]
    set lObjType [DboBaseObject_GetObjectType $lObj]
    if {$lObjType == 20} {
    set lEnableDS 1
    return $lEnableDS
    but when I use it from RMB and select signals in More it gives me right signal but invokes one additional menu command
    MenuCommand "65004" MenuCommand "14844"
    Similarly if I use keyboard shortcut it gives me previous Signal on navigation pane and invokes same menu command
    Can anyone find a fix for this.My version is 17.2
