  2. Allegro X Capture CIS
  3. Protect from wire connection on edge of hierarchical bl...
  • Replies 7
  • Subscribers 53
  • Views 11961
Protect from wire connection on edge of hierarchical blocks
MartinRose
MartinRose over 5 years ago
Hi all,
I find it hard to detect two pins of an hierarchical block that are connected by a wire link if the wire is placed on the edge of the hierarchical block outline. This has created faulty layouts in the past.
The picture below shows the issue where test and test2 are connected by a wire link.
Is there a way to prevent this issue (e.g. block wires on top of hierarchical blocks)? Or is there at least a better way to spot this?
Kind Regards
 Martin
  • MartinRose
    0 MartinRose over 5 years ago in reply to jc teyssier
    Hi jc teyssier,
    Thank you, we were also looking at the colour scheme.
    Is there a way to change the default wire thickness?
  • jc teyssier
    0 jc teyssier over 5 years ago in reply to MartinRose
    Sorry, do not know how to do this.
    You may separate more the pins(one grid step more) so the wire will be more visible.
