  2. Allegro X Capture CIS
  3. Display issues with Cadence and 4K monitors
  • Replies 12
  • Subscribers 54
  • Views 21718
soll
soll over 5 years ago
Hello
I have recently switched to a 4K monitor and I have a lot of compatibility issues with Cadence software suite. By default, all the softwares are blurry, so I go to the properties > compatibility > scaling on high DPI settings. For all the softwares I use, the problem is solved by this action. With Cadence softwares... The result is completely random. I have no problems with Allegro 17.2 and Allegro 17.4 (the icons are a bit small, but OK)
OrCAD Capture 17.4 :
All the icons are overlapping themselves.
Text size is normal.
The software is unusable as is.
image1  image2
Allegro 16.6 :
All icons and texts are incredibly small... I just can't use the software as is. Strangely, the text from the menus isn't affected (text like File, Edit, View...)
By the way I don't have the tbiconsize in my preferences... Don't know why...
image 3
I tried setting the ALLEGRO_HIGH_DPI_ENABLED environment variable which didn't do anything at all. I searched everywhere in the User Pref menus, found nothing.
Does anyone found a workaround ? Is there a config I am missing ?
I find that quite astonishing that the only software that has problems using high resolution display is... a CAD software... :p
Thank you !
  • excellon1
    0 excellon1 over 5 years ago in reply to soll
    Hi Soll
    I came across an appnote from EMA that may help you out so it is possibly worth a try to see if it fixes the Icon scaling etc. Here is the link.
    https://techsupport.ema-eda.com/support/solutions/articles/48001060574-modify-the-size-of-allegro-pcb-editor-icons-for-4k-screens
    Hopefully that will be the fix for you, let us know if it works. Maybe go with approach #2 in the appnote first.
    All the best.
  • soll
    0 soll over 5 years ago in reply to excellon1
    Hi Excellon and thank again for taking the time to answer.
    The configuration in the first approach is what I did with Allegro 17.4 and 17.2, I tried it with 16.6 and this is what causes the menu items to be so small (If I don't use this settings, everything is blurry). It worked really well with Allegro 17.4/17.2.
    I also tried to find that tbiconsize in the user preferences UI>General... But it is not there. I don't know why since it seems that most people can find this option.
    I will be in vacation for a week. After that I will update all Cadence softwares to latest update (couldn't do it this week as the IT guy isn't here this week).
    Thank you again !
  • steve
    0 steve over 5 years ago in reply to soll
    This user preference wasn't available until 17.2 so you won't be able to set this in 16.6. Remember 16.6 was end of life in Dec 2018 so Cadence will not have made changes like this to support 4k monitors. They are however supported in 17.2 and 17.4 which is what you are seeing.
  • soll
    0 soll over 4 years ago in reply to steve
    Hello Steve and thank you for the reply.
    Actually I don't have this option available in any version I am using, 16.6, 17.2, 17.4.
    We have updated Cadence to the latest patches available. Now 17.4 is completely broken :D All the windows have strange sizes, for instance the "Import Netlist" window is too small to display the buttons and the path field, and I can't resize it. I simply cannot import a netlist now.
    We have managed to find what seems to be the cause to this problem : The Windows option to adjust the scaling. I have it set to 150% (the value recommended by windows). If I set it to 100%, The windows in Cadence have a good size, but the texts are so small I can barely read them. What I don't understand is that every other software we use are working properly with this Windows setting.
  • excellon1
    0 excellon1 over 4 years ago in reply to soll
    Hi Soll
    I was wondering what video card you are using at that end ?.
    How do things look if you run at 1080p instead on that 4k capable monitor ?
    All the Best.
