  2. Allegro X Capture CIS
  3. Export CIS BOM report to excel is empty, unless the DSN...
  • Replies 12
  • Subscribers 55
  • Views 19375
Export CIS BOM report to excel is empty, unless the DSN file name is 9 characters or less
Zhifeng Jin
Zhifeng Jin over 4 years ago
Hi !
I have trouble exporting CIS BOM using OrCAD 17.4 S023, S024, S025 hotfix.
When the OrCAD DSN file name is greater than 9 characters,
the exported document is empty after executing CIS Bill of Materials - > Standard - > Export BOM report to excel.
Only when the DSN file name characters are less than or equal to 9 can CIS BOM be exported to excel normally.
This is a common problem of OrCAD 17.4 S023, S024 and S025 Hotfix. I tested that the reason why CIS BOM cannot be exported to Excel is that the length of DSN file name is greater than 9 characters.
I hope the test conclusion of this problem can give some help to cadence's R & D brothers. thank you!
Dear friends, if you also encounter that exporting excel using CIS BOM is empty, you can experiment。
As shown in the figure, the following is an experiment in which the length of DSN file name is greater than 9 characters:
As shown in the figure, the following is an experiment in which the length of DSN file name is equal to 9 characters:
  • Zhifeng Jin
    Zhifeng Jin over 4 years ago +1
    This is a common problem of OrCAD 17.4 S023, S024 and S025 Hotfix. I tested that the reason why CIS BOM cannot be exported to Excel is that the length of DSN file name is greater than 9 characters. …
  • Zhifeng Jin
    Zhifeng Jin over 4 years ago in reply to JON123 +1
    Yes, we require the use of the CIS component information base, so we are used to using the option in the report to generate bom directly into Excel. I didn't encounter this problem until I recently updated…
  • Yannick74
    Yannick74 over 4 years ago +1
    I have exactly the same phenomena and this is blocking me. The only workaround I found is : Export but with the Excel mark unchecked A report is shown in CIS windows, then File/Save As … to CSV…
  • drobny
    0 drobny over 4 years ago in reply to oldmouldy
    I have lost my patience ..... it doesn't make sense.
    We also reported other issues that have not been fixed so far ... For example, in HF13, CCRID 2322601 was fixed and yet is still present.
    I have reported it several times but they never corrected it.
  • omerG
    0 omerG over 4 years ago in reply to Zhifeng Jin
    I have still same problem this is basic mistake. How did they do it! it's funny. They are trying to write the design name as excel sheet name automatically then excel sheet opens as blank. is there any update about this issue. Our maintains time is finished.I didn't check new hotfix.
