  2. Allegro X Capture CIS
  3. Synchronization between CIS database, schematic design and...
  • Subscribers 52
  • Views 9633
Synchronization between CIS database, schematic design and layout footprints
SOT23
SOT23 over 3 years ago
We are currently using a CIS database (managed using a PLM software), Capture with CIS, and OrCAD PCB Editor Pro ; 17.4 S035.
We would like to find a way to synchronize a schematic design to the CIS database and to check whether the footprints used on the layout are the latest in the library.
Let's say we are designing a schematic, we use a component from the CIS database called PN001 rev 1.0. The netlist is generated and sent to the PCB editor. During the design phase, someone working on another project finds out that there is a problem with PN001's footprint. He updates it, not knowing that someone else is working on another project using the same CIS part. PN001 now has a new revision, PN001 rev 1.1, with a new footprint design (using the same name as the previous one).
Currently, when working on a schematic design, we have no way of knowing whether the CIS parts used are the latest in the database or not, the only way is to manually check each CIS part in the PLM to be sure it is the same as the one in the design ; that is not practical at all.
On the layout side, we cannot know if the footprints currently on the design are the latest in the library without updating every symbol on the board, which again, is not practical at all.
Is there a way to check, in Capture, that the database part revision used in the schematic is the latest in the database ?
Is there a way to check, in PCB Editor, that the footprint file being used in the layout is the latest in the footprint library ?
Thank you
  • SOT23
    0 SOT23 over 3 years ago in reply to steve
    I checked all the different licences I have available with CIS, and none of them had this option. Here is my Tools menu :
    But looking for this I found the part manager, that seems to be able to do something similar. Still didn't figured exactly how to use it but I am checking it.
    Thank you again.
